oggi è stato rilasciato un nuovo firmware per gli shelly 2.5, ovvero la versione 1.7.0.
Qualcuno sa indicarmi dove trovare il changelog?
Vorrei capire cosa è stato cambiato prima di aggiornare tutti i dispositivi...
Grazie!
Shelly 2.5 - New firmware v.1.7.0
Log changes:
Shelly EM and Shelly3EM Overpower protection added
Shelly EM and Shelly3EM Actions added
Shelly EM and Shelly3EM user can reset total counters and delete all data
Actions updated - devices can send actions to itself. To use that you need to input at URL field http://localhost/... for all comands check Shelly REST API.
Gateway in internet settings is optional
PlugS - MQTT topic for power consumption added
Short and Long push updated to be suppored from scenes
Auto On/Off countdown timer is supported from the Shelly App
Dimmer Warm-up feaure added, device can send wake-up impulse controled by time and power to the bulb when brightness is low.
Shelly1PM - user offset for power consumption is added and allow to calibrate device if needed.
Shelly1/PM Temperature Add-on, sensord ID is added in device status and over MQTT
Shelly Dimmer input debouce option is added in webUI
Shelly Duo - countdown timer for Auto On/Off is added in REST
Shelly Smoke - temperature offset added
`User-Agent` request header for actions added
Synchronisation between Cloud, REST and MQTT is improved which allow to set mutiple action URLs in next firmware (1.8)
RGBW2 - huge update:
After this update Shelly RGBW2 - Color and White mode is separated. Everytime when customer change mode, device update firmware with OTA. This is allow to have more Flash and RAM for current and fufure features.
Actions added in Color and White mode
Overall stability is improved significantly
Amazon and Google integration improved
Toggle command over MQTT added
Bug fixes:
Shelly1/PM Temperature Add-on, sometimes device stop reading temperture and humidity values
Sometimes after reset devices not return to AP
HTTP Login: max length of fields is fixed
Shelly 2.5 and Dimmer temperature measurement incorrect in certain conditions which can cause fake over temperature protection
Duo: Inconsistent JSON type
Backup Static IP cannot be removed
Security issue: Passwords are returned in plain format (settings)
Empty user/pass can be set but but this cause login issues
Duo forgets mode when controlled over MQTT
Some text in webUI is improved.
Another minor bugs are fixed
Bug fixes:
